Ok,,,,Im Back,,,,
By jashadams
Snapchat-1142015191.mp4 -
By Gwbarm
By Lance Workman
Kawasaki Prairie 700 is the machine. It’s starts and runs but has a miss. After running it til it’s warm, it’s start smoking like your spraying for mosquitoes. Has oil in the breather also. Checked compressions and getting low 40psi both holes. I know this has a decompression lobe. Any other ideas? Leak down check? I’m guessing it pretty much has to be rings. With it blowing oil back into the breather. Normal typical sign I suppose?
