2010 Can-Am Spyder RS-S SE5- Automatic (Miami, Florida 33144)
By docdoug72
By jwh
By quadcrazy
QUADCRAZY NEEDS YOU!
By Hagbard
Picked up a barn find that someone had already partially disassembled because the “motor locked up” but they never opened the case. Everything was bagged and labeled, and as I’ve mentioned before- I love a challenge ¯\_(ツ)_/¯
After a couple hours of fun with various pullers and hammers I managed to persuade the magneto/flywheel to come off. Hoo boy what a mess. Then I found an actual rats nest in the clutch cover. ಠ_ಠ
By heath
