    • By mga
      My 2000 big bear 400 4x4 has 26x10x12 tires in front and 26x12x12 in the rears. Trying to find replacement tires those sizes are hard to find, or, when i do, they cost a lot more than i want to spend.
      But, there's a lot of 25" tires out there the same size, just 25" and not 26". If i got the 25" it should not make a difference....right?
    • By p5200
      Can someone please tell me what size socket I need to remove the valve cover? Thanks! 🙂
    • By Dan Kroes
      Does anyone know what size wrench I need for the middle axle jam nut on a 2001 Polaris Sportsman 500 6x6? same part used on rear axles of these models.
      2000 INT'L BIG BOSS
      2001-2002 INT'L BIG BOSS 6X6
      2002 LUH 6X6 P
      SERIES 10 PTV 6X6
      1998 SCRAMBER 500
      1998-1999 SCRAMBLER 400
      2001 SCRAMBLER 400 2X4
      1999 SCRAMBLER 500
      2001-2002 SCRAMBLER 500 2X4
      2001-2002 SCRAMBLER 500 4X4
      2002 SCRAMBLER 500 4X4 FREEDOM
      1999 SPORT 400
      2000-2008 SPORTSMAN 6X6
      2005-2007 SPORTSMAN 6X6 MV
      2000-2002 TRAIL BLAZER
      1999 TRAIL BLAZER 250
      2002 TRAIL BLAZER FREEDOM
      2000-2002 TRAIL BOSS
      2001 TRAIL BOSS 325 SE
      2000-2001 XPLORER
      2001 XPLORER 400
      2002 XPLORER 4X4
    • By mywifeknowseverythin
      :yes:In everyone's so Humble opinion.....If you had the Cash.....and you were in the market for Either an 08 or 09 Utility Quad......Which Manufacturer would you Flip your Mattress for????
      Post your Reasonings.......And Which Quad you would buy...
      At the end of this Poll.....We will take the best two......Then Poll them..... Which would make this a True.....This Vs. That.....
    • By Phil
      I have a 2019 LTA-500 that needs a rebuild. The head assy and cover and cam is trashed. It seems like lack of oil feed to top end. Piston and cylinder is good. My main reason for posting is where is the cheapest place to buy parts?
      I'm in Australia but I have bought some parts before from Partzilla. I did find a reconditioned head assy on ebay from seller ATVcylinders, but still need a few things like cam oil pump, gaskets etc. I'm still looking for a workshop manual for this bike. Some photos of the damaged cam and head.
