    • By wheeliewayne
      my  2012 big bear 400 is hard shifting  can anyone help me
    • By TimothyLindblom
      Timothy
    • By Coyote251
    • By mga
      2000 Big Bear 4x4 400.
      do the front and rear drive shafts have to be lubricated? they have boots on them and i was wondering if i had to pull the boots off and grease the "U" joints? These are the ones close to the engine front and rear.
