Hello everyone, I am new to this forum. I am a senior engineering student in my final semester. My design team chose a new atv design as our senior project. We plan to design and build a go-kart which can go from land to water back to land on its own power. It would still operate on land as a typical go-kart does, perhaps with larger tires; we are adding a large fan to make it operate like a fan boat on the water, and of course a water tight base with enough buoyancy to keep it afloat. Part of our project is we have to prove there's a market for our design. So, my question here today is if this vehicle were on the market, would you be interested in buying it?
Thanks for your help :)
Oh, yeah! The quad ski. Maybe something a bit more rugged than this. Must be 4WD, low and reverse gears. Needs 4-wheeler land speed. Dosent have to be as fast on as a jet ski on water. Just stable and powerful enough to go up river.
Edited by Tim-ANC
i agree Tim, i think (judging from the videos) its much more a jet ski than quad.
the coolest thing i ever drove from land into water was this amphibious. when i was in my teens, i worked on an island (Nicholson Island Who knows about Nicholson Island? : Prince Edward County News countylive.ca) that was used for hunting for the famous and wealthy. they had 2 of these beasts ... and that car is bad a$$ !!
article-2246784-1678C96E000005DC-897_634x461.jpg.b7aa50d13c8af8b4586fac60c356dd59.jpg
    • By joshualutz
      so we got this little lt80 given to us when we bought my sons dirtbike as kind of a throw in gift it was just sitting not being used and my youngest fell in love with it so the gentleman we bought the bike from said we could take it as well for a little project
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By USRaider
      Hello all!
      Kept indoors but hasn't been run in 5 years.  We're not trying the engine until the gas is replaced, and the tires are reinflated. But the previous owner said their only issue was stalling when shifting to reverse without giving some throttle.
      I'm optimistic!  See y'all around!
    • By tin
      A few weeks ago, I foolishly asked my girlfriend about a quad that's been sitting under a tree at her parents' place for 25 years... This thread will be a sort of log of my attempt to resurrect it. I'm actually a computer guy, not a mechanic, so this will be quite conical for some of you, I'm fairly sure 🤣
      So far I've found out it's likely a 200. Not sure what year yet... The frame has a serial of 53J-001343 (I think). Engine appears to have the same number.
      We inflated the tyres on Saturday, which were still up today, so that seems a win. This also confirmed that the wheels do turn, as it rolled back into its 25 year old indentations as the 4th tyre started coming up.
      Oil looks used but otherwise OK. I'll change it if I actually get it running, but looks good enough for attempting to start it up again.
      Fuel tank had.... something in it. It smelt more like old stagnant water than fuel of any sort. Drained that out and flushed some clean fuel through to be sure.
      Fuel tap was jammed in the off position. WD40 and some force got it free. Did that after the fuel hose was off, so hopefully the carb isn't full of whatever it was in the ttank.
      Engine turns fairly easily with the rope start. Made typical exhaust puffing sounds.
      Unfortunately the rope mechanism was not fully rewinding, so I was limited to about half its length... And today it jammed fully pulled out. I attempted to remove the rusty screws, but one stripped it's head out. So for now the rope rewind is jammed.
      Spark plug connector seems possibly burnt inside. Black crap on both the plug and up in the connector, and the connector doesn't seem to actually stay on.
      Throttle lever is stuck fast. See photo for possible reason... Cable also feels jammed. I assume the throttle itself is jammed. That'll be fun given my skill level.
      Electrical stuff all seems dead. No headlights. No starter. No indicator lights. Could be a fuse. Could be bad connection. Not something I'm too worried about at this point.
      Front brake handle works. Parking brake clip thing was bent out of shape, but that's now fixed and working. Front brake only works on one wheel. Other one seemed rusted in place (off). WD40 and hammer got it free, although still stiff. Cable might be broken as it doesn't move at all when the handle is pulled.
      Rear foot brake works but needs adjusting.
      Other handlebar lever doesn't budge. Not sure if that's a clutch lever or rear brake... If this is the 200 version, I gather it's got a centrifugal clutch so it would be a brake lever... But I'm not yet sure exactly which model I'm working with. And the cables all disappear under the plastics and fuel tank and I didn't bother trying to trace where it goes yet.
      Thats probably about it for this post.
    • By HHurks
      Hi to all
      Newbie here. Not new to ATVs. Look forward to learning a few new things and hope to maybe help some too.
