Which ATV hold better value as used
I was looking to buy a new ATV
Polaris it a bit cheaper.
Let's say 3-5 years from now.
Exactly.. And some bikes need a lot spent on them, and some don't, and some get the money required and some don't. The value to the seller is mostly dependent on what they have spent on their bike.
The only real way to answer your question here and now is to look at your local second hand market.
Instead of looking ahead at selling it, maybe you should think about which would be better suited to what you will be using it for.  Then use it until the wheels fall off and have a lot of fun!  Worry about selling it if/when that day comes....
Reliability holding value and performance.  I have had a 250 since 89 and never done anything to it except starter, its now worth twice what I paid for it. Just my opinion, never rode a Polaris they may be good. In my area the Hondas bring the biggest price  on the used market, Foremans and Ranchers second is Yamaha, Big Bears and Kodiaks running in good shape sell immediately.
Southern US as a whole Honda is always going to hold value better in the long haul.  Polaris is a love hate, personally I hate them because there are so many one year only quirks, harder to work on because some things just don't make sense.  Hondas have more or less looked the same since the 80s.  Two different target customers for those two machines though so really impossible to compare.
If I was buying a new one, I would go to all the dealers sit on them and see which one is the most comfortable and fits you best with ease of controls, you are going to be sitting and driving this for a while and I wouldn't compromise comfort , they are all good as long as you maintain them and not terribly abuse them, you will be fine.
On 3/5/2023 at 10:48 AM, RjMaan said:
Yeah, I have heard about reputation about Polaris but personally I really like Honda Rancher. It is way more powerful and stylish.
I guess you meant the other way
Also have to consider how far you live from a dealership.  Nearest Can-Am, and Honda dealer is an hour away, Kawasaki, Suzuki is 30 miles away. Yamaha and Polaris is 15 minutes.  I don't see many Hondas while running around the countryside.  Honda makes an excellent machine but numbers speak volumes.
Having owned and worked on a lot of ATV's, I like Honda.  They are well built and mostly bullet proof.  As for performance, I love my Outlander 1000.  As for value, I have to go with Honda.  My Honda rarely needed any work or repairs.
Canned Ham has a weird reputation for being unreliable but it's pretty unfounded.  the Outlander 650/850 and especially the 1000 make enough power to destroy themselves.  Without throttle control and common sense an outlander will eat itself alive.  The 650 for example weighed 680 lbs and had 72 HP...that's a recipe for fun.
Here in Wyoming, Honda wins in my opinion.  Honda is built MUCH better than others, especially Polaris.  I have owned and worked on many ATV's.  The only thing I had to do to the Honda is clean the carb after it sat for about 6 years before I acquired it.  That being said, I have never had to work on my Outlander 1000 and it has a good resale value.
in short, Honda.
Personal opinion but I would says Honda without a doubt
  • Similar Topics
    • By twheelerk
      Hello I have a 1981 Honda atc 200 I recently rebuilt starts first, second pull no problem, changes through the gears no problem but the only problem I am having is when I give it gas it pops an sounds like it is choking out. I picked up a carb for it seamed too help but still bogs alil when giving it throttle an loses some power…also I have too run this new carb on half choke, any advice would help thanks
    • By Notallthere
      Hi everyone This little monster came to me as a non runner and to sort it for a friend. Had it in bits thrown the service bits at it but nothing, it struggles to turn over unless you put your hand over the intake then it spins like a demon. The valves are adjusted correctly and I am just lost where to go next.
    • By Filthy_Mule777
      I'm currently pulling my hair out over a customers 98  bayou 2x4 KLF300b. I've changed every electrical component on it twice and in a couple instances three times. Still no spark, I am baffled. Initially customer brought it to me complaining of a hard start no start situation and in fact, it wouldn't start. I changed the starter relay, spark plug,  CDI box, and starter circuit relay after which it fired right up ran very well but then started having issues with the neutral switch/light where it wouldn't come on and wouldn't allow it start or even turn over. I found in the wiring harness a loose connection, I got it taken care of and secured and that solved the problem. So now that it would crank up again and run fine I called the customer over to test it out see what he thought as I've never heard it run before and I wanted to get his opinion on how it was running. Customer ride it around a little bit pulled it back on my carport and turned the key off and said it was great, and had never ran better or started so easily, then we set up a time for him to come pick it up the following day and he left. Well where he pulled it on my carport and shut it off was in the middle of the carport so I jumped back on it to park it off to the side,  crank it up no problems put it in reverse went about maybe 18 inches and it stalled and ever since that point it has not had spark or run. I replaced the CDI box again with a better brand, I replaced the ignition coil twice put another starter relay on it and I've also changed out the stater and the pick up coil (pick up coil twice) and I'm just I'm lost I don't know what else to do to it. I've had this customers  four wheeler for four months now whereas he's a patient guy I need to get it out of here so I can move on to something else. I've seen dozens of threads across  different sites for off-road, 4 wheelers, ATVs, UTV's, whatever and they are all experiencing the same sort of issue but they never ever post hear the problem was or  the fix. So I'm hoping somebody here has a little bit of knowledge on this particular issue sent since it seems to be so widespread.  Thanks in advance for any help or suggestions.
    • By DrtyGrlKristin
    • DIY like a pro! Shop from over 1,000,000 Repair Manuals at eManualOnline.com! As low as $14.99 per manual. Shop now.
    • By Adamap1
      Hello everyone. Looking forward to joining some discussions here and learning as much as I can! Just bought my first atv and it needs some work but I love to tinker. Looking forward to it!
  • Gallery Images
