Hopefully someone here can help me out. I am getting ready to build a pulling tractor using an ATV engine and need some advice. These are garden tractors that are converted for pulling a sled just like the big tractors do.
The class I am interested in allows the use of an ATV/three wheeler engine. It can be up to 400cc, but has to be a single cylinder, four stroke engine. We are allowed to modify them, but they have to be run on gasoline, and are not allowed to use any form of supercharging or nitrous. We can start out with a smaller engine and use a big bore kit, but the final size must be 400 or less.
My question is, which engine would have the most power potential for something like this? I am not concerned about brand loyalty or anything like that.
Any help would be appreciated.
Thanks for the info. Is there any year or years that are better than others, or did these engines stay similar through the years?
EDIT:
This may sound like a dumb question, but I am not ATV savvy by any means. After researching, I see people referring to the DVX400 and KFX400 engines as being the same. I know Suzuki and Arctic Cat have relations, but is the Kawasaki KFX400 engine also the same? If so, it will make searching for a donor quad a little easier.
Chris
Edited by Chris65
Im not sure who built what for who. I would stick to the Suzuki motor unless you can find out who builds each others motor.
Im a Honda guy so hopefully a Suzuki expert can help you on years to get
Sent from my myTouch_4G_Slide using Xparent BlueTapatalk 2
Edited by marioweldinginc
It will probably be a while before I start this project, especially since I need to find a donor for the engine, but I will definitely document it. We are also planning a tractor build with a Vmax4 snowmobile engine for another class, and I am in the process of building a stock car for my friend's kid right now, so my plate is kinda full. We do document our builds of everything though, so I will share pics here when we get started.
    • By WeeBee
    • By digrig
      Hey everyone,
    • By BillR94
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
