Hey everyone,
Im sorry to hear you are having trouble with one so new. As technology is changing so quickly these problems are becoming harder to diagnose. There are so many relays sensors electronic components that can heat up causing these problems then go back to normal when they cool. Do you have any error codes or display warnings or used a code reader to see if any were saved.
My first thought would be an electrical componet heating up causing it to stall, but it could also be low fuel pressure if the stalling occurs as you increase speed, if it is very consistant stalling at a set speed you could be loosing spark. Not much help, many things could be causing this, you have done the most obvious things that could cause this. More information might help, does it just quit or studder pop or backfire before stalling.
  • 7 months later...
    • By Joeguy
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By Dsluder
