1986 Honda Fourtrax 250R
By quadcrazy
QUADCRAZY NEEDS YOU!
By BillR94
Thank you for your time
Bill
By davefrombc
It would be helpful at times to have a button where we could cont the Admin. to make some changes to our posts.
By Banshee898
2014 Honda Rancher TRX420TM1: Unit starts right up, once it warms up it stalls and more difficult to start but once it does start it won't stay running. I have replaced the fuel assembly, IACV, O2 sensor and fuel injector. There are no active DTC codes. Disconnecting fuel line at injector and turning on key there is a steady stream of fuel. Plug looks good did not see crack in ceramic. Is there any way to test the ignition coil?
Thanks for any help.
By WyattLemke25
Working on a 2016 Sportsman 570 and it has a new battery and spark plug. No codes, fuses all look good. It cranks for a while and when it starts it will only run for a few seconds before stalling. At one point it was running at 3000 rpm with no throttle input, then it dies. Not sure where to look besides messing with the throttle cable, so suggestions are appreciated, Thanks.
