Son put snorkel kit on bike yesterday, now runs a little rough when you lay off throttle and sometimes stalls. When I take off airbox cover it runs perfect, this would mean when I have cover on the snorkel is giving less air, right?
So, less air it is running too rich or too lean?
Thanks, Kirk
    • By Ejwill
    • By TimothyLindblom
      Timothy
    • By gwares
      Price : 2500 EUR
      The Ultra Bee T offers the fastest acceleration of any road-legal electric motorcycle at this price-point, with the flexibility to deal with a wide range of surfaces. With its huge capability the Ultra Bee T will appeal to people looking for a great medium distance commuter, that’s also able to turn its hand to off-road riding and green laning.
      Everything works and new!
      We try to capture everything in photos for you.
      If you have any questions or need other photos, just ask, thanks.
      Send a direct message to make an inquiry or text:
      WhatsApp: +33 758 56 21 59
