from what i have seen, most problems are from the angle sensor. also noted that the seals on the electrical components were not up to par and it would be a good idea to take them apart, clean them, and use rtv silicone gasket on them. obviously you have an electrical burp in that system. could have come from water/mud leaking thru ... just a thought ...
how is you battery? is it fully charged and holding the charge?
Edited by oxidized_black
    • By jeffrocdx
    • By HighPlainsIT
      My son's trying to get a 2003 Prairie 360 running. Over a year ago, he'd rebuilt the carburetor using a SHINDY 03-112 rebuild kit from JT Cycle & ATV, and it was working fine; however, when it wouldn't run recently, he took the carb apart and the jet needle was rusted in place. He cleaned that up as good as possible and replaced the jet needle with the old one that wasn't rusty. Now, he can only get it to start about 1 out of 5 tries, and when it does start, it won't run unless the choke's on. The spark plug's good and is sparking. It has compression. Any ideas on what he should try next or look into?
    • By Asand211
      I've got a 1995 220 Bayou and the electric start does not work.  When I got it the machine was pretty rough but I was told it ran less than a year ago.  The key switch had been cut off and wires  twisted after the key was lost.  I bought a new ignition switch and repaired the wiring and it is working correctly.  It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button.  I verified there is no voltage going to the starter from the solenoid.  The fuse in the solenoid is good.  Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on.  That doesn't make sense to me but I could be wrong.  I would appreciate any help I can get. Thank you in advance.
    • By Martin82
      Hello to all, could somebody help me to get the electric diagrams for Polaris Sawtooth 200 , i have issue with missing spark , and also with turn signal,
      I need to verify whole wire harness wiress and connectors , and weldings , and massa connections , but i need the electric wire diagram for it.
      Thanks for your support.
      M
