hello riders
Picked the atv up not running. owner did know not why it wouldn't start.(kinda fishy) tore it all down. previous owner put brand new piston in it and gasket set. No marks on the piston so it wasn't running after he rebuilt top end. someone been in it. LOL. checked rings. all ok. Valves are seated.timing dead on.
put it all back together.
Well the 2002 honda 400ex still won't start. Went through everything again.
The spring and plunger for the decompression cam is missing. Will this make it not start. Has the stock cam in it.
What do you guys and gals think????
Edited by terry001
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
    • By WeeBee
    • By joezee13
    • By middlebrookgt
