2000 Arctic Cat 1000 - Service Manual
By cavry
O3 sat a while. Engine is running fine. I got it into neutral, did some general tune-up and cleaning then pulled the shifter pedal up and it locked up and will not release into neutral again. Does anyone have experience with this problem? Thanks for looking and any help.
Cavry
By tepin
By flyinbrian365
Factory service manual
By flyinbrian365
By flyinbrian365
What's Covered:
