Hi all,sure hope someone can help. Have a 87 lt 4 wd, started running rich. Flooding after shut down and wouldn't idle. Rebuilt carb,was nice and clean inside. Now it starts fine but will not idle,too lean.will rev fine. Drilled out the pilot jet just to see if that would change things and it will idle,but loads up too much. Also played with the float.Tried different pilot jets but after a few still no good. Have just about given up. Was trying to find one of the after market carbs that will work. My intake side is 30mm. Anyone have any ideas ???? By the way I own a PWC sales and service co and spend a lot of time doing carbs....never had one like this !!
Are you the original owner? Just wondering if a different model carb found its way in there. There are different jet components for these Mikuni carbs depending on ATV model. You could try raising the needle jet to enrich the mixture.
No Im not,but looks like the rite carb. Did raise the float but no luck.The only thing that made any diff.was drilling out the pilot jet, will idle but loads up. Tried a few stock pilot jets a bit larger but no better....
    • By BillR94
      Thank you for your time
      Bill
    • By joezee13
    • By middlebrookgt
    • By Ejwill
    • By nduray3
      Is there anyway to make the pilot screw accessible on a 1996 Suzuki king quad
