hi im new to this page and i was wondering i have a kolpin 90cc atv that i got through a trade for a snowblower. It obviously sat in a mud puddle for awhile the stator was full or mud and crap but is now clean and creating current it also has a new cdi and coil but still no spark any ideas?
I dont have any manuals for your machine and dont know how your ignition system is setup but I assume it is like all others. Since you had problems with the stator I would check the pick up is getting the pulse from the rotor to signal the CDI to juice the coil.
Also check fuses, wiring and grounds are good. Particularly check connectors for dirt and corrosion.
Do you have a wire diagram for this?
      any ideas how to correct
    • By middlebrookgt
    • By mattgoodwin
      I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
    • By JPRICE1981
      Hello everyone !! Looking for some help !! Im wanting to check my stator and pick up coil with a ohm meter and cant seem to find a guide that tells me what to read and what my reading should be !! Any help would be great !! THANKS IN ADVANCE !!
    • By Machias_Mike
      Just looking for a second opinion before I start ordering parts.  It looks like from the below tests it must be a failing stator.
      Background - quad runs fine but when I use winch it will drain battery, I can then pull start but even after running for 20 mins if I turn it off, battery still dead and does not seem to get charged at all.  Voltage at battery after charging using trickle charger is 12.5.  Start up and voltage shows 13.1 at idle, if I rev it up voltage drops to 12.5.  LED lights also flicker at night even with fully charged battery.   Really more annoying than anything and if it is stator I prob will not change until it becomes more of an issue or maybe during next oil change.
      Thanks for looking, appreciate any replies!
      Stator plug and letters show how I tested.
      [ ]  A  [ ]
      B      C
      Checked resistance on stator (manual says .1 to .7)
      A = .7
      B = OL
      C= OL
      Voltage   idle and 3/4 throttle
      A = 31/55
      B = 15/33
      C = 15/32
