Ok everyone, I've been rebuilding the top end of my vinson 500 and here is my problem. After replacing all the gaskets and getting my timing set I was all set to place the head on when I realized I had left one of the two small sleeves that position the cylinder head on the base. To go back and put it in would require another complete tear down. This is one of those round cylindrical tubes that the jug sits on. All bolts are in along with Indian head gasket shellac on both sides of the gasket, my question is what might it hurt if I don't put it back in? Honestly I can't see where it will matter and setting the timing on this machine is a real bi***. Anyone have any thoughts on this?
    • By toe420
      I got a couple yamaha moto 4 225cc quads. The guy gave me several old starters with them. I see kits are available to rebuild them but does anyone have tips or tricks for doing it? I haven't rebuild a starter before so im not sure what to look out for.
    • By ButchM
    • By Baldwin007
      I was wondering if anyone out there has a digital copy of an Owners Manual for a 2003 Suzuki 500 Vinson 4x4? I have a service manual, but no Owners Manual. I would like to know how to correctly operate/engage various features.
    • By dkgg5755
    • By Damien911
      Setting the timing on a 2005 Yamaha 250 Bruin
