I have a 2003 trx 350 fourtrax thats not charging .I replaced the rectifier last yr and want to know how I can test it or the stator with a multimeter? I tried to download the manual here but the link must be dead cause I can't get anywhere with it. Iam attaching a pic of my meter so someone can tell me what settings cause I don't know alot about multimeters.Thanks
Try reading ACV on the 200 scale. Dont know a bunch about your Honda but Harley which have a rotor-stator system will produce about 28 volts at a fast idle. As the RPM goes up so will voltage. Measure each combination using two of the three wires coming from the stator
  • 2 years later...
First , with your meter set to DC and on 20v range like you have it in the pic, read the voltage across your battery.
second, start your atv and read across the battery while its idling. you should read 12v without it running and 14v with it running.
    • By cavry
      Cavry
    • By flyinbrian365
      Factory service manual
