neutral light does not come on when in neutral, engine will not turn over. have not found any bare wires or loose connections. not sure exactly where the neutral switch is located or how to replace it. battery is hot and reverse light works
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By sandman001
    • By wilmpie
      hi everybody
      thanx in advance
      any ideas how to correct
