By Shadow soul60
So I want to put LED headlights in my 99 Bayou 220. The stock headlights have some issue in the connector and they only work some of the time, so I want to replace them with LED light bars. I want to run them off the high beam switch. Which wire would this be?
By drobbie98
Hey all, Thanks for having me in the forum. I just purchased my first ATV and am stoked to understand more about it.
The first stupid question will be, what is everyone's maintenance schedule? DO yo follow the recommended intervals or build one yourself based on the machine.
Thanks in advance.
By El_Guapo
Hi folks, im working on a kazuma Falcon 250 with has the ubiquitous 3 lug 8" wheels. have a set of polaris ranger wheels and tires that i would like to use on this little atv. they are the standard 4 on 4 bolt pattern. Any recommendations for wheel adapters to achieve this? (double whammy as the wheel track will get wider with adapters). cheers!
By Acme54321
I am trying to run down a problem with my Bayou 220. I think it's a 96.
The battery has been dead for years. Years and years. It pull starts right away and I don't use it a ton so I hadn't bothered to put a new battery in until now.
I've got a new battery in it and now nothing works that should (and used to). The starter, headlights, and dash lights are all inop. I've looked at the wiring diagram and done a little messing around and haven't had any luck.
Fwiw the starter works when jumping the relay. The 4 wheelers pull starts and runs fine.
Any ideas where to start?
