I'm not familiar with the Polaris, but I think it's got a master cylinder at the brake handle. Fill up the master to the top, close it. Have someone pump the brake pedal and hold it. Loosen the bleeder slowly to remove air (at the brake caliper, or center). The pedal will sink. Close the bleeder. Pump it up again until the pedal is hard and hold it. Loosen the bleeder to remove air and the pedal will sink again. Close it and check the fluid level. Repeat these steps until you are confident you have a good pedal.
    • By Eisenmatt17803
      Good Morning!
      Thanks in advance.
    • By n4cer26
      Hi!  The wife and I are planning to head to Indian River this fall for a couple days to ride the ATV trails.  Looking for a good place to stay that is close to the trails so we can ride from the lodging location. Any recommendations or tips on Indian River?  Thanks a million!
    • By n4cer26
    • By Rickm59
      I have a 2022 Kymco MXU150 and have been trying to bleed the rear brakes for several days. I have used a vacuum and also tried the lever pumping. i took the caliper off and compressed the piston with a C clamp and had a tight brake lever. I put it back together and still cannot build any pressure in the brake system. Any ideas from anyone?  Thank you
    • By TravisCr
