2007 Suzuki Vinson - rear/Hand brakes
By vaneleus
By Olchap
Thank you,
Olchap
By RussB
Has anyone found a rebuild kit or an aftermarket replacement for the original which costs 500.00 US dollars?
By Rickm59
I have a 2022 Kymco MXU150 and have been trying to bleed the rear brakes for several days. I have used a vacuum and also tried the lever pumping. i took the caliper off and compressed the piston with a C clamp and had a tight brake lever. I put it back together and still cannot build any pressure in the brake system. Any ideas from anyone? Thank you
