Join Today, It's Simple and FREE!
By Pete Barber
Pull in clutch lever shift into gear and nothing happens ... But When I pull in the clutch lever I hear a clicking sound ... never heard this before ...
By Wesley Floyd
Hey guys, Thanks for looking at my post. I haven't had a lot of experience with problems like this before, so I'm a little bit at a loss. The Quad was really hard to shift, (the dirty carb leaking gas making it idle high didn't help either). The only Idea I have would be is that the torsion spring is worn out, and that there is a normal parameter for how much it should move when those two arms of the shift shaft assembly spread apart. That's my thought. Maybe someone who has more knowledge then me can let me know if i'm on the right track 😀
By flyinbrian365
View File 2019 Textron Wildcat Trail Service Manual
This Textron Off Road Service Manual contains service, maintenance, and troubleshooting information for the 2019 Wildcat Trail. The complete manual is designed to aid service personnel in service-oriented applications. This manual is divided into sections. Each section covers a specific vehicle component or system and, in addition to the standard service procedures, includes disassembling, inspecting, and assembling instructions. When using this manual as a guide, the technician should use discretion as to how much disassembly is needed to correct any given condition. This service manual is designed primarily for use by an CatMaster Basic Level technician. The procedures found in this manual are of varying difficulty, and certain service procedures in this manual require one or more special tools to be completed. The technician should use sound judgment when determining which procedures can be completed based on their skill level and access to appropriate special tools.
Submitter flyinbrian365 Submitted 02/18/2019 Category Textron Off Road UTV
By flyinbrian365
View File 2015 Textron Motors MPE 850 Diagnostic Manual.pdf
4-Stroke Engine
MPE 850 OFF-ROAD
This diagnostic manual is valid for the following engine models:
409135 I2 846 UTV NA-80
By flyinbrian365
View File 2015 Textron Motors MPE 850 Maintenance Manual
Maintenance Manual
4-Stroke Engine
MPE 850 OFF-ROAD
This maintenance manual is valid for the following engine models:
Similar Tagged Content
By YamahaGrizzly
Complete Grizzly build
I built this Grizzly to preform at top ability in the mud! There is a few things that i am looking to change on the grizzly but well see!
Tires:
Gorilla Silverbacks 28x10x12 Front, 28x12x12 Rear
( https://atvtirescanada.com/gorilla-silverback-tire.html )
Snorkel Kit:
N2Deep Customs
( https://n2deepcustoms.com/ )
Bars:
Rox Speed FX risers and bars
( https://bit.ly/2TsRv18 )
Exhaust:
2r Racing tip
( https://amzn.to/2GgNdpE )
OR
( http://2rracing.com/ )
Clutching:
White Secondary spring. 8 - 16g rollers, 1.5mm shim
( bought at local dealer )
Rad Relocation kit:
( http://www.rubberdowncustoms.ca/ )
Lights:
12" Light bar
( https://amzn.to/2TrfZYy )
Rock Lights:
( https://amzn.to/2TpF9Xu )
Flush Mount LED headlight conversion:
( https://amzn.to/2D10Lm8 )
Yamaha front Bumper
( bought at dealer )
Handguards:
Powermadd
( https://amzn.to/2DQwmIR ) - guards
( https://amzn.to/2S2BCSq ) - mounts
3/4 inch spring spacers
(made myself)
Winch line:
Synthetic winch line
( https://amzn.to/2Gj1S3F )
By Alan Callison
Hello boys and girls!:howdy:I need a little help if ya dont mind.I need to replace the rear axle bearings on my 400 but Im going at this blind having never done it before. Ive looked it up in the repair manual but it doesn't give any specific steps on how to do it. I've got the left rear brakes off already as I was replacing the shoes anyway. Can somebody give me a rundown on what Ive gotta do please?I know I need to pull the right wheel off just havent done that yet. Do I need to take anything apart in the final drive or elsewhere in order to yank the axle out for instance? Which side does the axle come out from,L or R? Any details I need to know will be greatly appreciated.Thanks ya'll!
By stymy68
So I'm trying to figure out the year of one of my Timberwolf's. I have 4.
2 are definitely 1993's, as I can read the serial number on those.
1 has to be close to a 93, as the back rack and lug width (156) are the same as the 93's.
The last one is killing me. Someone painted over the serial number.
Listed are the differences
Back rack is different. It goes through the plastics and will pivot on the rear attachment. Doesn't have the handles out the side, either.
Doesn't have the loops coming out of front plastics.
Foot rests are different.
Lug pattern is 110.
Everything I've read, says that the Timberwolf was produced from 92-98 and then changed name to Bear Tracker. Most parts are interchangeable through those years. Only change I found, was front brakes were upgraded to disk in 2001.
By Alan Callison
I just got a 2004 Yamaha that needs some work.Its got wet brakes on the front that Im trying to get working.My problem is the brake lever.This the lever on it now.On the master cylinder it has a cable in it that has the wire that fits in a slot inside the lever itself but this lever isn't made for that.I dont know if whoever had it before didn't know what they were doing or what but its the wrong lever for this machine. Can someone point me in the right direction here? I looked at the Yamaha website and the schematics only show a part that looks like this one here. Again,I have a 2004 Yam 400 Kodiak 4x4 and its an automatic model. BTW,the master cyl. was bone dry. I was gonna change out the rear brake shoes and when I went to pull off the wheel,get this, each wheel stud had 2 different sized washers holding the lug nuts to the wheel rim. The stud holes were so worn out it had worn away the base of the studs and the holes were the size of quarter! Im lucky someone didn't die while riding this! A word to the wise.Pay attention to what you buy.Look carefully and keep a keen eye out. This was my fault because it was the 1st ATV Id ever bought and I didnt notice alot on this machine so I guess I count myself lucky in that I didnt get hurt nor did anyone else who rode it either.
By Scoopeddad
I have a 1994 big bear and I am starting to have issues starting. I put in a new starter and selnoid as the at stopped starting with the electrical but will still start with the pull cord. Where and what now should I be looking at to check? If I turn key to on and the switch to on then hit the start button, the bike clicks and then nothing. Lights still work but no response to the starter. Stumped now. Any help would be greAt.
