Join Today, It's Simple and FREE!
By Pete Barber
Pull in clutch lever shift into gear and nothing happens ... But When I pull in the clutch lever I hear a clicking sound ... never heard this before ...
By Wesley Floyd
Hey guys, Thanks for looking at my post. I haven't had a lot of experience with problems like this before, so I'm a little bit at a loss. The Quad was really hard to shift, (the dirty carb leaking gas making it idle high didn't help either). The only Idea I have would be is that the torsion spring is worn out, and that there is a normal parameter for how much it should move when those two arms of the shift shaft assembly spread apart. That's my thought. Maybe someone who has more knowledge then me can let me know if i'm on the right track 😀
By flyinbrian365
View File 2019 Textron Wildcat Trail Service Manual
This Textron Off Road Service Manual contains service, maintenance, and troubleshooting information for the 2019 Wildcat Trail. The complete manual is designed to aid service personnel in service-oriented applications. This manual is divided into sections. Each section covers a specific vehicle component or system and, in addition to the standard service procedures, includes disassembling, inspecting, and assembling instructions. When using this manual as a guide, the technician should use discretion as to how much disassembly is needed to correct any given condition. This service manual is designed primarily for use by an CatMaster Basic Level technician. The procedures found in this manual are of varying difficulty, and certain service procedures in this manual require one or more special tools to be completed. The technician should use sound judgment when determining which procedures can be completed based on their skill level and access to appropriate special tools.
Submitter flyinbrian365 Submitted 02/18/2019 Category Textron Off Road UTV
By flyinbrian365
View File 2015 Textron Motors MPE 850 Diagnostic Manual.pdf
4-Stroke Engine
MPE 850 OFF-ROAD
This diagnostic manual is valid for the following engine models:
409135 I2 846 UTV NA-80
By flyinbrian365
View File 2015 Textron Motors MPE 850 Maintenance Manual
Maintenance Manual
4-Stroke Engine
MPE 850 OFF-ROAD
This maintenance manual is valid for the following engine models:
Similar Tagged Content
By frank marano
View File 1997-2002 Yamaha Raptor Supplementary Service Manual
Submitter frank marano Submitted 11/24/2018 Category Yamaha ATV
By Xyla Cat
View File 2004 Yamaha YFM350S Supplementary Service Manual
Submitter Xyla Cat Submitted 08/25/2018 Category Yamaha ATV
