Hi,
  I bought a 2001 yamaha warrior 350 recently. I went to go tighten the chain, as it was very loose. I did everything as I should. I loosened the upper and lower carrier hub nuts, and adjusted the adjuster bolts. However, no matter what I did the chain would not get tighter, nor would it get looser. What could the issue be? The chain and sprockets were just replaced by the previous owner, so thats not the issue. When the bolts are adjusted all the way in, they just touch the carrier assembly. What could my issue be that the thing won't adjust? Could it be if it wasn't in neutral? I am fairly certain i had it in neutral though. Should I unbolt the skid plate, will that cause it not to move?
    • By cfherrman
    • By Yamahahahaha
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
