I think you need to troubleshoot it to see why its not starting and first thing I would do is check all fuses and wiring to see why the display will not light up. Then I would check ignition assuming you aren't getting anything when trying to start it. Need more info here to better understand where you are with this.
    • By Mister907
    • By Brent Wright
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
