By jeffinotown
By captnunu
I have a 2007 kingquad 450 fuel injection. I try to start it with the hand crank and almost flip over the quad. I have taken the hand crank off and cleaned it but this did not fix the problem. I believe there is a decompression valve that is supposed to engage when pulling it over by hand. How can I check this?
By dp19
Hi, I'm a newbie on here. I just got a 2007 Suzuki KingQuad LT-A450X. Are there any specific issues to look for on this model? Any specific maintenance to do other than the usual oil and filter changes?
By Louznmemind
