By
Guest Fox300exchic
in For Sale or Wanted? Post it here.
By BillR94
Thank you for your time
Bill
By wjmedic
right front hub again
By sunn
Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs? Right now that panel is wide open with excess heat on my leg.
By TravisCr
By DemonQuad666
I'm sure this has been tossed around on here numerous times but with the unveiling of the new KTM fuel injected 2 stroke. Could this be the first step in a come back for my beloved double ding ding machines. Ok lets hear it. Why do you like one or the other??? Myself, I always felt it was the throttle control and Powerband response with the 2 strokes. I know this sounds weird but on a 4 stroke, no matter size or model. I always felt like i was along for the ride instead of in control. I've spent hours on my buds 400EX, even took a new 450r for a spin. before they discontinued them. Blasters, Banshees, and a number of 125's, 250's and even one late 80's Honda XR250R... Results all the same. For me its a comfort and control that im used to with the 2 strokes.... and i love the smell of bean oil... So lets hear it. Im sick of arguing with same two people at work on this issue.
