Thanks for the reply. It's a 2006  Bombardier Outlander 800.  Fuel leaks are especially dangerous here in California in the height of fire season.                                                Just wondering how much I'm going to have to take off to get to that hose. I've changed the oil, but am pretty sure I'm going to have to hire someone to take on the hose replacement.
  • Ajmboy changed the title to 2006 Bombardier Outlander 800 Fuel line leak
    • By Dsluder
    • By buriedpast
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
      I generally use Non Ethynol fuel in all my small engines. I just got back from the gas station and that fuel has really increased in price since last year, I will continue to use it, even though its north of 1.00 a gallon more. That seems minor compared to cleaning and repairing carbs every year.
      I was just curious as to what others are doing in regard to gas in their quads, i know a lot of the newer ones are fuel injected which shouldnt pose a problem, but i have had lots of problems with rust and jell forming in carbs when using ethynol fuel.
    • By ButchM
