86 lt 250r Need help.
By BuckBilly
By P_syko
Are the cheap tires from Amazon any good? I know nothing last forever, but don’t want them to dry rot in a year.
By DZL1
Thanks in advance.
By alain
I just got this quad from my father in law need some tlc. Will need a new battery and does not know the battery PN as I don't have service manual. When my father in law had it , it uses lots of plugs, never got it service to verified why , he just buy an other plug and was good for a other 4 to 6 months .
Any one would havd answers would be appreciated. Thanks
By TimothyLindblom
Timothy
