Hola!
I bought this baby yesterday, wasn't running - but a carb clean and new battery brought her to life and she sounds and drives like a beast.  Ugly and beat up plastics but w/e
So, the carb was nasty - like green buildup and every port possible and was clogged.  Where else should I look to clean or change fluids?  Also, anyone have the lt f500f SRV manual?  I did not see it in the SUZ forum for manuals.  What causes green buildup in carbs?  I am new to ATV's, but have at least dabbled in doing all my own auto maintenance and am trying to get the kick in the right direction as to what to service next before i ride her full time.
I do know that there is an oil leak that appears to be from the clutch cover gasket but will get under and clean it all up to confirm exactly where its leaking from.
Thanks!
Additional Info,
I just checked the carb and it appears to be leaking fuel from the pilot screw just forward of the float bowl.  I did not mess with this screw when I disassembled the carb.
Any thoughts?
    • By cruteg8
      I was thinking about trying to repair some cracks in the plastics of a Lakota Sport i just purchased has anyone ever tried (U.S. Chemical & Plastics USC GarageTM Flexible Glaze USC-77704 it) https://www.ebay.com/itm/364866165725. i was thinking jb weld for plastic then using this as a bondo that can be sanded smooth
    • By 88classic
      I have (2) sets of brand new plastics available for Honda Rancher 420 2014-2023. These are genuine genuine OEM Honda plastics. One set is white and the other set is green. The boxes these are in are too big to ship.(Unless you want to pay for it. If so, lookup your own shipping rates from 17325 and box size is 58"x35"x18").  $400
    • By LMI
    • By tds7
