I see that ridegear.com is a sponsored link for this site. I ordered a Blingstar Grab Bar from them and they sent me the wrong one. It would not fit my quad because there is not a mount for my exhaust pipe. They would not return any emails, I called numerous times. Everytime I called I would either get a message saying their hours are 8-5, call back. So I would call back during their business hours and I would get a message saying they're too busy to accept calls, call back. So here I am, 4 months later stuck with a grab bar that I can't use. Still no email response.
Oh sorry, :unsure: I will have my wife look at her Emails so I can get all that info for you. I will even get the purchase date and all the info I can. I would love to get the right one. Thank you very much for your help. Even if you don't get through, thanks:wink:
    • By marlon smith
    • By goatman
      quad is a new to me freebie, pulled carb and cleaned it. got it running and idling nice but mid throttle it craps out and will go down to almost a stall, i release throttle and it just sits there idling away happy as a pig in poop. i was thinking fuel restriction then i noticed the exhaust glowing red in the sunlight. so its running lean
    • By goatman
      bottom of the tail pipe was rusted out and the little nut also ripped off when i tried to undo it.
      a 540 ml soup can is the same id as the exhaust pipe od and the soup can has ridges to make it a tight fit
      a little bit of a mickey mouse fix but it works
    • By Sonders
      Hey everyone.  2007 Sportsman 800 and the exhaust on passenger side is getting so hot it melted the bottom side of the seat.  It's not low on coolant or anything.  Any ideas what would cause the exhaust to get that hot?
