1998 king quad 300 exhaust manifold glowing red
By kevinohio
By LMI
By kevinohio
By kevinohio
My cylinder is full of gas.i thought if carb was messed up.gas came out the overflow.had a cheap china made carburator on it.i ordered a factory used one.couldnt find a new one.also the fuel shut off isn't working right.and going to be needing the battery hold down and seat bracket.where can I get a used one?
By Gwbarm
It seems every ATV i look at to buy used has no title, does everyone loose there title, or do they change hands so often the title is lost in the shuffle. The ones that do have titles are triple the price. I am new to buying used quads is this pretty standard procedure.
I know all quads are good and tough but thought it might be good to hear opinions as to what member think is the best, from your experiences.
