Hey everyone.  2007 Sportsman 800 and the exhaust on passenger side is getting so hot it melted the bottom side of the seat.  It's not low on coolant or anything.  Any ideas what would cause the exhaust to get that hot?
Thats bad! Have you checked to see if the engine is running hot. One of the listed problems with this particular model is overheating due to a clogged radiator. The other thing i would check if the engine is not overheating is the exhaust flow make sure the exhaust is flowing freely and no debris or mud is caked up around the cover that lets air circulate to keep the exhaust cool. The only other thing i can think of is if it is running lean it could have a tendacy to overheat under certain circumstances, might try some injector cleaner in the gas. Just a few ideas to check.
thanks for this items to check out.  It had an aftermarket single exhaust pipe on it when purchased, but I put the stock dual exhaust back on it as I didn't like the super loud aftermarket exhaust.  I wonder if the stock exhaust could be partially clogged up from sitting around in barn for years.  Radiator is clean, so it's not that.  Not sure how to check to see if it's running lean?
You might check the exhaust for blockage also the spark arrestor if equipped. I reviwed your photos again it definately got hot for some reason , even the seat was melted. I would take the cooling cover off and make sure it is clear. As far as running lean probably not you problem, but things to look out for:
Poor Acceleration
Surge with a steady throttle
Deceleration Backfire
White looking spark plugs, they should have a dry Tan appearance.
    • By Mreoiwerk
      Hey, I'm thinking of upgrading my stock sport glide seat with memory foam as a bit of a project. I've seen how some guys use the heavy-duty padding inside the water repellent UTV seat cover fit Polaris Ranger XP 1000 crew for their UTV projects and wanted to try something similar for my bike.
      Has anyone done a DIY foam upgrade and have any tips? What sort of foam density would people recommend, and how easy is it to remove and refit the factory seat cover over the new padding? Any advice gratefully received!
    • By mehim
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      AWD and differential repair
      Brake system service
      Popular related searches:
      Sportsman 570 wiring diagram
