OK so I bought a 4 Wheeler the other day for my son i was told that it was a 50CC meerkat the playoffs and France are that of a meerkat but the motor has a 86 CM stamped on it.... i did some research and everything i keep finding says it's a 90 CC motor... but it has no shift lever on it where the should be one it's just blocked off..... please help thanks
Did someone shave the shifter lever?  As far as I know, they had either a 3 speed foot shifter or D-N-R shifter lever.  I would say automatic but I don't see where the clutch would be attached.  I'm not totally knowledgeable about these but I can locate a friend who might.
    • By oztrax
      MAX 4 6X6 2008
    • By Callaway
    • By Maddman200
      Who agrees with me that Yamaha atv quailty was one of the best well built quailty machines money could buy, then 2007 came rolling in and they have gone to complete sh**. Cutting corners everywhere they can and made such unreliable machines
    • By hunky
      Thanks for looking!
    • By shorty
