Bottom one is a drain/overflow hose. It should be routed down through the bottom of the bike and just sits open at the bottom for fuel over flow if the carb floods for any reason.
The next one if I’m not mistaken is the fuel line connection.   I have the bear tracker   I will try to take a look when I get home for you.
So I looked and it’s not the Fuel it’s a vent hose.  I can’t tell where it’s going without removing the tank or daylight so I can find out exactly where It goes for you tomorrow.
i pulled up the manual and have attached a pic so you can see.
Click on the pics and zoom in, you can see its shows it’s a vent hose. I just dont remember where it goes off the top of my head.
  • 7 months later...
  • 2 years later...
    • By mehim
    • By logray
    • By ebertz28
      Looking at 2 quads and need help deciding. #1 is a 2021 CF Moto 600 Touring with 69 miles, 2 seater with factory installed plow, windshield, backrest and luggage box with no warranty remaining  for $6500 or #2 2022 CF Moto 500 with 15 miles and a 2 year warranty for $6000?
    • By smipha
      Does anyone have a 2017 polaris ranger xp 1000 hunter edition service manual I can download? The one I have only shows things about the prop shaft for a crew model and mine in a standard. They have different shafts mine is cv not u joint.
