Need help 1999 scrambler 500 4x4 oil line issue!
By Werewolf
By JohnnyB
Greetings,
By Mhatayas
By Spritee1
not sure where to look next
By Roofus
I cant seem to find what this part is called. Can anyone point me in the right direction? I must be misinterpereting the parts catalog or something? I dont see it in the rear axle section. I think it may be in the rear brake assembly section? click link to view picture.
[removed broken image]
