Hello I'm new here and not sure on where this should be posted but here goes. I have a 2007 Kawasaki 360 4x4, it started to make a small knocking sound and few weeks ago. I checked all the normal things and didn't find anything. I just used it around the house as my yard machine, no real heavy loads or stress on it. And it ran fine with no problems. Well one day I went to roll my yard with my roller that i filled with sand. It put the 4wheeler under a load for the first time, well it ran fine for about 20 mins then i stopped to do something and it started but there was nothing there. It would not rev up enough to engage the belt drive and the knock got a lot louder. Sounds like the knock is coming from the top end. And ideas in where to start. I have worked on some stuff and mechanically inclined just never tore into an engine before.
Welcome to Quadcrazy, I had a similar problem in my bayou 400.  The knock turned out to be a worn out cam journal.
If your problem is the same this is what I did.
I had to pull the valve cover off exposing the cam.  You will see the opposite side of the cam, the end without the sprocket. It will look worn discoloring and scored. Also the valve cover itself will look worn where the cam sits.  The knocking is the back end of the cam flopping around.  The valves don’t operate right and I lost power.
Maybe this is the same problem as yours maybe not.
It took me a little while to isolate the knock but either way the engine had to come apart just to start looking in the engine.
I wound up finding a used head and cam in excellent condition and installed it with fresh valve seals and I was good to go.  I thought the reason this happened was because the oil pump was failing and maybe not pumping oil to the head. I checked it and no problem. But double check yours.
I hope it’s something along those lines and not deeper like a main Bering. I would start to look at a few different parts on eBay just to get the ball rolling and see what’s out there. Taking  the valve cover off is not a big job. Plastics and gas tank go first  and then you can pull the cover.
Good luck and keep us posted.
Well here is what I found so far. The valves and cam look good no slop or anything, gap is right on both. So I took the timing chain cover off and there is way to much stack in it. Took the tensioner out and it's in good working condition. Put it back in and it never even got close to taking up the slack. Took the plug out to check timing marks and it is out of time by like 3 teeth. So going to order a new timing chain but need to get a 35m 1.5 thread flywheel puller. They want 110 for new one, but found one on ebay for 25. So waiting on them to show up and go from there.
I looked at where cam sits and covers. There were no marks or anything anywhere. Rotated cam by hand with wrench on rotor nut under pull start to look for any type of score marks on cam and nothing again, everything was tight and no movement or slop at all. That's when I decided to check the timing marks. Sorry I didn't think to take any pics of it while doing it.
Ok well got the puller and new chain and gasket Saturday. Took the old chain out and laid it next to new one and you can defently see it was stretched. Put new one on and all back together. Made sure timing was good. It fired right up and ran smooth. Let it idle for a little bit no leaks or anything. Took it out for a small ride and runs better then before for sure. Thanks for your help Frank.
  • Thanks 1
    • By Atomusthenes
    • By RadRob
    • By Tim Keiper
