I hope the "Kids ATV Forum is right place for this.
I have an early (?Year) LT80.  Doing lots of work to slowly get it working.  Is there any way to judge how much oil coming form the oiler pump into the carb is about right?  I searched here but found nothing...I likely was using the wrong term but had no luck.
Peter
  • 4 months later...
Not really what you asked but i removed the separate oil mix all together, got rid of the pump, hoses and the oil container and premix the gas for it. Feels alot safer for the engine. The little metal piece
that runs the pump looks very weak. I used the space i got where the oil container was and made a big battery box so i have a 18Ah battery in it now.
    • By joshualutz
    • By BillR94
      Thank you for your time
      Bill
    • By Asand211
    • By McClaw
      I've narrowed it down to the Polaris Sportsman XP 1000 S or the Honda FourTrax Foreman 4x4 EPS
      What do you guys think?
