the main thing is to make sure the tie rods are the same length and the tie rod end bolts are the same diameter.  you might be able to order a tie rod and use just the tie rod end off the new one if the sleeve is too long or short for your quad.  just make sure your looking at the same diameter threads for everything
    • By umax33
      i just got a 1986 honda trx 200 and the reverse and neutral lights don't work, i looked in the service manual and it says to remove two screws and the cover comes up and you can check the bulbs, the book does not show the two screws and i can't see them.Does anyone know how to get to the screws to check the bulbs. i will appreciate any help i can get...thank you
    • By docdoug72
    • By Atomusthenes
    • By Trent Finnessey
