There are certain pieces of advice picked up along the way that make life easier. You know, those valuable little lessons, like when your Mother told you to eat your vegetables, or when your Dad said "buy cheap, buy twice."
More...
I dont agree with the first tip where it says to use wd-40 or atleast with o-ring/x-ring chains it drys them out and causes your chain to wear faster. Plus is dosnt keep your chain lubed for over a 2 hour period and even less when riding though water and snow.
    • By WeeBee
    • By BillR94
    • By GERONAMO308
      Hi all, does anyone know what type of plastic is used for making ATV fairings.
      In particular Suzuki Quadrunner 1992, if i cannot get a plastic for it in Red for the rear i will attempt repair.
      I have a King Chrome plastic welding kit, however you need to know what type of plastic you are welding.
      Any advice would be greatly appreciated.
      Are the cheap tires from Amazon any good? I know nothing last forever, but don’t want them to dry rot in a year.
