2006 Polaris Sawtooth Set Timing and Valves
By LashinWheeler
Any help would be great,
Thanks!
By Martin82
Hello to all,
Im looking for a main wire harness for Polaris sawtooth 200,
Thanks for info
By Martin82
Hello to all, could somebody help me to get the electric diagrams for Polaris Sawtooth 200 , i have issue with missing spark , and also with turn signal,
I need to verify whole wire harness wiress and connectors , and weldings , and massa connections , but i need the electric wire diagram for it.
Thanks for your support.
M
By Thebritish
My bayou 250 came to a stop and would not not start, it turned out the starter clutch had a fit and died. I changed the starter clutch which had sheared off the 3 bolts attaching it to the flywheel and everything went smoothly. However, when I went to start it I found it would not start. On investigation I found the timing out of whack, by alot. Thinking it was something I did on the repair, I repeated the process of removing and reinstalling the starter clutch and related components and resetting the engine to TDC. Tried to start and immediately realized the timing was out of sync again.
Is there something I'm missing? Could there have been a bigger issue, possibly on the other side of the engine? I don't understand why, with a brand new starter clutch there would be such movement in the crank. The timing chain and sprockets do not look worn and appears to be tight on the tensioner. When I move by hand everything appears to move as you would expect. But when I try to start it using the starter or the pull start it goes out of whack!
