Hello from NC ladies and gents. Been lurking here off and on and don't think I have ever posted up.
I have a 2009 Honda Rubicon. I was having a shifting problem with the Hondamatic. Determined it to be a loose connection on the gray 21 pin connector at the control unit (ECM/PCM). I located a source for the connector and replaced it. This improved the connectors feel greatly, HOWEVER, even though I thought I was careful transferring the wires/pins from the old connector to the new connector, I must have crossed up a couple wires because now the gear position display (switch is new) no longer works. It worked fine before the connector change.
No matter where I have looked, I cannot find a "pin out" for the ECM connectors. The factory service manual does not show it and I have a connection at a dealer and their service techs don't have the pin out either! I was a Chrysler/Plymouth/ Dodge tech in another life and cant imagine th factory not providing pin out diagrams for diagnostics!
I am at a loss unless I either replace the harness, OR find someone that can take multiple photos of the wires going into the gray connector so I can compare mine.
Any help or advice would be appreciated. I will also post up the location I found the connectors if that is allowed, since it seems that they fail with some age.
connector source:
Motorcycle Connectors
We have Vintage and modern Sport-bike Motorcycle Wiring Harness electrical Connectors, These connectors are purchase directly from the manufacturer, And in many cases the OEM Supplier, The terminals and connectors are superior quality. Most are Manufactured in the, Japan, USA or Europe. Bullet...
www.cycleterminal.com
    • By Joeguy
    • By Cj Winds
    • By KIWINZ
      Hello
      My son scored a free Moto4 - late 80s from the looks of it. I don't know anything else about its history as the owner wasn't there when i picked it up. Can't see the VIN number as its a bit rusty.  He cleaned the carb and then with some either it started and still starts first pull.  Its runs really nice - not rattles etc.  Goes forwards well and the brakes work fine so it looks like a keeper, However, we have only managed to get it into reverse once.
      1) it won't shift down into what seems like where first would be - 2nd and upwards only. The changes between gears is fine.  No crunching or missed gears - just no first gear.  2nd gears appears to be as low as it will go
      2) the clutch - when you hold the gear lever up or down works (only the second ATV we have had.  Other is a Quadrunner which doesn't have this feature)
      3) no neutral light - will start when no in neutral - should it do that?
      4) the one time we did get it into reverse the neutral and then the red (reverse) lights worked. Swapped easy between forward and reverse - when it went into second, it didn't return to first or neutral
      5) checked the clutch adjust on the RHS - seemed fine to me.  When i turned the screw back 1/8 it was where it was to start with.  Clutch doesn't slip.  The bike will move forward is all gears.
      Any help would be appreciated
      Andrew
