2007 Kawasaki Prairie 360 Brake issue
You can see in the pic the lower cable is slightly pulled.  I'd loosen both off and make sure the brake arm moves freely.  If it moves freely, then look at the cable.  I'm assuming the lower one is a hard line that goes to the foot brake?  Is it slightly depressed?  Maybe some lube and everything that moves and it'll come back to life.  either that or the rear shoes are so worn that the cam is stuck between the shoes.
    • By oxidized_black
    • By mga
    • By jashadams
    • By McG75
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
