  • Admin changed the title to Suzuki King Quad 700 give it gas then it dies
Clean the carb, dump the fuel and replace with new, and change the fuel filter. It's most likely some water in your float bowl and will idle ok because it's only pulling small amounts in at idle but when you hit it it wants to suck up a lit of fuel but theres to much water so it dies.
KQ 700s are EFI. It's likely the throttle position sensor that's faulty or out of adjustment, or a faulty fuel pump. You can see what the EPU thinks the TPS is doing by looking at the lines on the bottom of the dash when you turn it on with the diagnostic jumper wire in.
    • By WeeBee
    • By Zrach
      I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
      This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
      Note: This modification compromises the factory “no-start” circuits.
      On some malfunctioning CDI units the internally damaged circuitry is only partial.
      Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
      The Modification
      See the second diagram attached below for the wiring specifics.
      The Result:
      The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
      ⚠️ IMPORTANT SAFETY WARNING ⚠️
      Please be aware that this modification compromises the factory safety "no-start" circuits.
      The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
      Faulty CDI Workaround.pdf
    • By BillR94
    • By GERONAMO308
      Hi all, does anyone know what type of plastic is used for making ATV fairings.
      In particular Suzuki Quadrunner 1992, if i cannot get a plastic for it in Red for the rear i will attempt repair.
      I have a King Chrome plastic welding kit, however you need to know what type of plastic you are welding.
      Any advice would be greatly appreciated.
