2020 cforce 600 hard to shift
richard fischer
I have a new 2020 cforce 600 touring and read how smooth the shifting was on it. Mine however, sticks in gear quite often and only after moving the bike around does it finally shift. I use the brakes before shifting as it says but that doesn't seem to affect it either way. Anyone have this issue? Is there an adjustment on the linkage perhaps? Any suggestions are appreciated. The machine is new with about 10 miles on it.
I have the same problem with my new 2021 cforce 600 . the machine is new with 5 miles on it . Taking it back to the dealer ,didn't buy it to work on it .I hope they can solve the problem.
I just purchased a 2021 600 Touring and today, with less than 10 miles, I experienced the gear shifter 'locking up'.  I also noticed when riding in H, the N light was illuminated...how?  It's in H, not Neutral (N).  In addition to the shifter issue, the 600 Touring also ran hot....mid-60s...still in 'break-in', running as instructed by manual and sales staff.
    • By pitts
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By newguy024
    • By HSTAR
    • By jatho
