I have a new 2020 cforce 600 touring and read how smooth the shifting was on it. Mine however, sticks in gear quite often and only after moving the bike around does it finally shift. I use the brakes before shifting as it says but that doesn't seem to affect it either way. Anyone have this issue? Is there an adjustment on the linkage perhaps? Any suggestions are appreciated. The machine is new with about 10 miles on it.
I have the same problem with my new 2021 cforce 600 . the machine is new with 5 miles on it . Taking it back to the dealer ,didn't buy it to work on it .I hope they can solve the problem.
I just purchased a 2021 600 Touring and today, with less than 10 miles, I experienced the gear shifter 'locking up'.  I also noticed when riding in H, the N light was illuminated...how?  It's in H, not Neutral (N).  In addition to the shifter issue, the 600 Touring also ran hot....mid-60s...still in 'break-in', running as instructed by manual and sales staff.
      Topics covered include:
      AWD and differential repair
      Brake system service
      Popular related searches:
      Sportsman 570 wiring diagram
    • By KIWINZ
      Hello
      My son scored a free Moto4 - late 80s from the looks of it. I don't know anything else about its history as the owner wasn't there when i picked it up. Can't see the VIN number as its a bit rusty.  He cleaned the carb and then with some either it started and still starts first pull.  Its runs really nice - not rattles etc.  Goes forwards well and the brakes work fine so it looks like a keeper, However, we have only managed to get it into reverse once.
      1) it won't shift down into what seems like where first would be - 2nd and upwards only. The changes between gears is fine.  No crunching or missed gears - just no first gear.  2nd gears appears to be as low as it will go
      2) the clutch - when you hold the gear lever up or down works (only the second ATV we have had.  Other is a Quadrunner which doesn't have this feature)
      3) no neutral light - will start when no in neutral - should it do that?
      4) the one time we did get it into reverse the neutral and then the red (reverse) lights worked. Swapped easy between forward and reverse - when it went into second, it didn't return to first or neutral
      5) checked the clutch adjust on the RHS - seemed fine to me.  When i turned the screw back 1/8 it was where it was to start with.  Clutch doesn't slip.  The bike will move forward is all gears.
      Any help would be appreciated
      Andrew
    • By jeffrocdx
    • By wilmpie
      hi everybody
      thanx in advance
    • By sunn
      Any ideas?
