Hows evryone feel about blasting around in snow ?
I love it usually after all plowing is done ill drop the plow and just go lut and have fun. From drifting all over lol to packing snow trails in woods its fun , never been into snow mobiles ,  where we live its very rural and our roads seem like an afterthought when it comes to plowing lol , usually last to get cleared , so we will hit the back roads to powerlknes and such , we have several people around here with side by siedes ,and the usually hit the powerlines , pack the trails and then we hit them good fun ....Anybody else ?
    • By joezee13
    • By middlebrookgt
    • By Ejwill
    • By Ejwill
      I live about an hour west of Savannah and was wondering if anyone knew of places to ride in this area. Only place I know of is in North Georgia, about 4.5-5 hours from my house. Would like to find something closer.
