2016 efi sportsman 450 ho crank no start
By Flash_fella
By Werewolf
By Brantley11
Hey everybody,
Here is where we sit:
New 93 Non Ethanol Gas
New Spark Plug
Bluish white spark
Good Compression
Here are the readings:
By Gwbarm
By Spritee1
not sure where to look next
