I'm generally against Chinese crap. Niche pistons for instance are known to blow to pieces in a 400ex. However, I picked up a Niche pinion and ring gear for a 300FW and am pleasantly surprised that the ring gear is actually welded. The pinion in it decided to commit suicide so I had to salvage a case half and buy a pinion and ring set. Had new bearings and seals though so recycled those. Lash is really decent too. We'll see if it stays together.
Edited by MarkinAR
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
    • By Trent Finnessey
    • By Dumass
    • By DaveswMN
      Thanks for any thoughts.
