DS250 for a 7yo?
By toe420
Hello everyone, I have a 92 honda trx350 I just picked up that has a bent section of the frame where the rear of the seat would clip into place. It almost looks like a tree or something heavy fell on it. Its a fairly deep bend, if that makes sense. It like a V instead of straight. What are peoples goto methods for straightening a section like that?
By joezee13
After turning off engine in neutral starter wont engage If I rock unit back and forth it engages Getting progressive worse.
By pepsidude1979
has anyone have experience changing oil and putting chain lube on the chain im just wondering if its easy for someone that isnt mechanically incline with mechanical stuff i can do the basics like check/add oil, change air filter, check tire pressure
By mga
I have a Yamaha Big Bear 400 4x4 2000. I've posted on here about the frame being bent. Does anyone know what year frames are interchangeable? Also, would the frame from a 350 be the same as a 400? Would it matter if it was a 4x4 or 2x4?
thanks for any help with this
By Brian Emerson
Hi Guys, this Quadmaster has an extremely loud bang after turning key off (from idle), scares the stock, dog and missus, any ideas on what to check.
Thanks and regards,
Brian
